Cam questions
I run 1/4 and 1/3 mile track, 5.2 Rod stock bottom end, 500cfm, stock clutch assembly, round tooth pullies, 14 inch tires 75 inches round, turning 7700-8000. I've tried the 304h cam over and over again very dead on these tracks.. Any other suggestions
Contact Esslinger, Schneider, Crower, & Comp Cams. Fill them in with your specifics above & they'll be able to tell you the best cam to run. Dave
is your head ported? if not then you will find that the Holley 350 carb will much better suit you
