Bare Johnson Machine Heads
Johnson Dport big valves lightly ported strapped deck .130Also have D4 Intake also LG Journal .30 block with balanced and prep crank 2"I have a few other builder heads also Oval port stock valves deck .120Full port and polished solid fat tapped .530 lift & .550Lunati cams 42903 & 42907. Reed Cam .580 soludAlso (6) Qa1 Aluminum small body shocks with custom leaf spring bracket $500 ( cost 1600 )Stock super light weight fly wheel Ford 2.3 Crank Honda Cut rod journals 1.88 Stroke at 3.275 build CC will be 2460Chevy Rods & .30 kb pistons Used $100Custom powder coated Green Ford Valve cover2 bare Dport heads fully ported ready for machine work. 719 242 7147
