What in the world kind of car was that?!?!?
I just saw a picture of him passing Richards for the lead in a heat he won and I swear that car must be articulated. No "down links" from the roll bar to the rear clip and the entire center section of the frame is at a different attitude than the rear. You can clearly see the rear of the chassis through the LF wheel opening and there is no way that is directly attached to the center section of the car. Not to mention the LF is about 2 feet off the ground.
And you can see something UNDER the car that doesn't look normal.
See DoD slide show for the picture if you haven't seen it and chime in with ideas but this is some strange stuff.
