I have a crown Vic clip lightning we can not get the power steering to work right. When you raise the rpm over 2500 the steering will come and go. We have changed all components with no luck. Any ideas?
I don't even here crickets Brad
put a GM box on it like I told ya' and should fix it.
Lares sells a Ford Saginaw box....same as Chevy box just Ford bolt pattern...it's part number 807
I think the boxes are in the $300 range...haven't bought one in a while so not 100 percent sure
Selling a steering box comes with free race car
I run a stock Crown Vic steering box with no issues at all. Sweet pump with remote reservoir. Are you sure you are hooking all the lines up correctly?
as low as $93.79 at rockauto.com also $118, $141. $162 etc.
Sorry 807 was fast ratio box...std one was cheaper
