Crash101
Ultimately, filing up with nitorgen is the best i assume. But not having those means, how else do you guys air up tires. Do you have an inline air dryer system? A cam air system? Whats the best and most logical way? How is blowing up 20 tires onto the bead for the weekend done if you use nitrogen? How do you get moisture out if you used regular air to seal beads. i wouldnt know how anyone has time to vacuum pump moisture out of every wheel. How far will a nitrogen tank last?
