What are most peiples opinion if after the feature your left rear tire was warmer than your right rear tire? Hoosier g 60 imca tire. Neither had much heat but left was warmer than right
I would check and make sure the axle tube is straight. If the RR is buried in a sticky cushion, and the LR is in the black, I could see the LR being hotter than the RR, but most of the time you are laying on the RR and the LR is unloaded pulling on the chain. Even tire temps are good, but I don't know about hotter on the LR. Another thing to think about is, how many mud holes did you drive thru getting back to the pit area. Tire temps are only accurate taken on the racetrack as soon as the run is over.
Any time my LR has been hotter, the car was tight as hell.
