Brake snubber instead of sixth coil
Just thinking here. Instead of a sixth coil, would it not be better, traction wise, to use a brake snubber on top of the rear end, as a shock with a spring and/or rubber, or a telescopic snubber with no shock? It would push the rear end up, loading the rear but it would also take some weight off the rear springs and put some into the fronts.. What do you guys say? Is that way out to lunch? Has anyone tried that? Still used with a lift arm just not with a sixth coil.
