I have a 14 1/2 degree motor from Malcuit. This off season had a engine shop put new sleeves in refreshed the whole motor. sense then have sent it back 3 times because it smokes. IT appears to be water from intake I believe. When you take the carb off you can see all runners are wet. HE has tried to seal it but still the same. I pressure tested it with radiator and it looses pressure of about 10 lbs in less than 5 minutes. I originally thought was the head gasket but water seems to be only in intake. Looking for ideas what we are missing or if someone has a good motor guy who could look at it asap. Really need help so frustrated. it is 428 all aluminum Dart Block .
