Winters, Wilwood, Victory, Woodward, Fivestar, TWM and many more parts for sale
Item Part Condition Price Each Quanity
Allstar 36" gun drilled axle New 115.00 1
Allstar 36" gun drilled axle straight Used 50.00 1
Allstar 36" gun drilled axle needs straightened Used 25.00 1
Allstar 35" gun drilled axle needs straightened Used 25.00 1
Allstar 35" solid axle New 45.00 1
Allstar 33" gun drilled axle New 85.00 2
Allstar Chevrolet 2 piece engine stand New 50.00 1
Allstar Firebottle mounting brackets Used 20.00 2
Beyea (Longhorn/Victory/Mastersbilt) Mild steel Tri-Y (Chevy) headers Used 400.00 1
Beyea (Longhorn/Victory/Mastersbilt) Stainless Steel Tri-Y (Chevy) headers Used 800.00 1
C9 Enterprises Door bar plates Used 50.00 2
Coleman Aluminum drive shaft 38 1/2" Used 100.00 1
GM 4 blade fan Used 50.00 2
Hans Sport Hans device (outdated SFI sticker) Used 100.00 1
Hoosier Misc. used tires Used 50.00 100
Howe Low friction lower ball joint Used 33.00 1
K&N Air filter Used 20.00 1
Keyser Radiator Used 100.00 1
Longhorn/Victory Front Bumper Used 125.00 4
Longhorn/Victory Rear Bumper New 75.00 1
Longhorn/Victory J bar mount plates New 40.00 1
Longhorn/Victory J bar mount plates Used 20.00 1
Longhorn/Victory LR radius rod plates New 25.00 2
Longhorn/Victory LF sweet style spindle Used 100.00 1
Longhorn/Victory RF Sweet style spindle Used 100.00 1
Longhorn/Victory RR upper shock mount plates New 20.00 1
Longhorn/Victory LR upper shock mount plates New 20.00 1
Longhorn/Victory RF Keyser spindle Used 100.00 1
Longhorn/Victory Birdcages used only 1 race Used 750.00 1
Mastersbilt Interior aluminum angle New 40.00 1
Mastersbilt RF Lower Control Arm New 75.00 2
Mastersbilt Front T Bar New 35.00 4
Mastersbilt Rear T Bar New 35.00 4
Mastersbilt Door Bar New 35.00 1
Mastersbilt Rear bumper New 75.00 1
Mastersbilt RF spindle Used 50.00 1
Misc. Rods/Ends Misc. Rods and ends Used 100.00 1
MSD Blaster HVC coil New 100.00 1
Performance Body MD3 nose White New 85.00 1
Performance Body LF MD3 flare white New 40.00 1
Performance Body RF MD3 flare white New 40.00 3
Performance Body Rocker panels black New 25.00 3
Performance Body Complete Lower Valence (flo orange) New 60.00 1
Performance Body Left side lower valence (black) New 30.00 2
Performance Body Lower nose supports New 10.00 6
Peterson Oil Tank mounting brackets mount to 1 1/2" round Used 60.00 1
Peterson Oil Tank mounting brackets mount to square tubing Used 40.00 1
Quickar 4 guage panel New 150.00 1
Rocket Lift Bar New 75.00 1
Rocket RF Spindle Gray New 50.00 2
Setrab Oil cooler Used 200.00 1
Strange Oval 35" gun drilled axle straight 1.180 diameter Used 100.00 1
Strange Oval 33.5" gun drilled axle 1.180 diameter New 175.00 1
TWM J-Bar 20 1/2-22 1/2" New 125.00 1
TWM RR birdcage New 300.00 1
TWM Climbing J bar mount Used 50.00 1
TWM 8 1/2" angled upper control arm New 65.00 2
TWM 8 1/2" angled upper control arm Used 40.00 2
Wilwood Drive Flanges Used 25.00 4
Wilwood Dynalite caliper Used 75.00 1
Wilwood Dynalite brake pads "B compound" axle set New 50.00 1
Wilwood Superlite brake pads "DTC 30 compound" axle set New 85.00 1
Wilwood Brake rotors 1.25" brake rotors Used 15.00 4
Wilwood Brake rotors 1.25" brake rotors New 30.00 2
Wilwood Superlite brake pads "B compound" axle set Used 20.00 1
Wilwood Dynalite brake pads "BP 40 coumpound" axle set Used 20.00 1
Winters Gear set 8525 5.34 Used 35.00 1
Winters Gear set 8518 6.12 Used 35.00 1
Winters Gear set 8501 4.86 Used 35.00 1
Winters Gear set 8502 5.04 Used 35.00 1
Winters Gear set 8512 5.42 Used 35.00 1
Winters Spool Used 100.00 1
Winters LR side bell New 200.00 1
Winters axle tube 26" Used 75.00 1
Woodward Power steering servo New 100.00 1
Longacre Air guages Used 15.00 2
XS Power 16 volt battery Used 50.00 2
Call or text 765-993-2078 to purchase
also visit www.stevecasebolt.com for detailed list and pics
