I have an 04 smackdown and need to replace some tubing. Were the chassis built using mild steel or did they use anything else then? Thanks
Pretty sure most of them were dom back then. Even on "chromoly" cars alot of the smaller diameter tubing is dom
Cut my front end up last night. It has a seam on the inside. Probably CREW
No argument their billet. Ne all tubing has a seam the designations can be a little misleading. The seam is different and can usually be used to identify the tubing type to a certain degree
