TheJet-09
I don't recall seeing it discussed much, but what are some averages you might see on 6th coil travel? I know there are many variables (all the track and driver differences), but when I ran a 2.5" spring (400#) I would typically see around 1/2-3/4". I should point out that I also have the old/bad driving habit of dumping the throttle and stabbing the brake (especially when there is traction available)...
But my current reason for asking is that, if I have my lift bar set-up properly in my car (2017 Lazer), my center to center on the fifth coil shock is 19" (only allowing me another 1" of travel under decel/rebound). Does that sound acceptable, or should I be concerned I might fully extend the shock?
As always, thanks in advance!
