missile07
The day I put the Integra on at the track it had a 125 single spring on it. I smashed it to our extended load number and stuck it on and didn't change anything else. This had the static ride height alot higher than normal, but I didn't have other springs to change it or make a stack. It had the car really really jacked up on the LR corner, so much that the driver had to use a tire to stand on to get in the car....last night we stuck a double stack spring (66 lbs) on the integra and got the extended load correct and static load close. It would not lift it.
With the spring rate being higher(125) and the static ride height already being higher with the combo on at the track, have the car high enough that it was easier to transfer that weight or is the static ride height high enough that it could possibly be past a bind in the suspension?
