Who makes these springs ??all I can seem to find are 9 1/2 ".I've even considered taking a plasma cutter to my 9 1/2's.
Two things ive tried all the above and nothing worked, i had a streetstock guy who is a setup king in our area explain it to me. My car pushed like a bulldozer , when i corrected it id either shoot to the left or overcorect and end up shooting towards the outside wall. After getting schooled in how our suspensions work i started thinking how i could make it work for my driving style. You want to start with jets recomended setup front and rear with only a 100#the difference up front, your springs should be 5 1/2 x 9 1/2 600 or 650 rgt or 700 or 750 lft front. The J bar pinion mount wants to be as low as you can go in the pinion mount , the frame side wants to be around 3-5" above the pinion side this angle will allow your rear to come up and off the bars controlably. Rember this to heavy of a spring in the front will not allow your car to transfer to the left front creating your bite witch allows you to steer it. Its like a pendulem .
I'm not sure I can follow that advice.Remember we are talking about metric midsized mods(not streetstocks)with metric lowers which have a motion ratio of 23% versus jets chevelle and metric impala stubs which have a 35% motion ratio or in other words650x.35=227.5 for the chevvelle while 650x.23=149.5 isn't that a little light???As far as j bar goes i had mine center of pinnion and 3 to 5 up on frame and it made no difference.The biggest thing we are struggling with is the push that happens when the frontend components bottom out whether its the shock, lower, or tie rods.From what I've encountered there is no problem getting weight to transfer to the front if i(we) are bottoming out.
I cant believe you are bottoming anything out with how bound up your front end is. Too many people focus on the rearend trying to get their car working when the front end is really messed up. On metric lowers 800-900lbs springs should be good, if you are having problems with those rates you need to look at your geometry.
Just to clarify this , you are working on a IMCA mod correct , i do run a mod not a street stock , trust me try what i said it will work if not good luck .i tried every concievable spring combo in the upper numbers and it wont work .
mine is a ump mod. Cavemod? I'm beginning to think one could achieve a balance two ways here. One stiff fronts, high j/bar. Two light fronts low j/bar. We did'nt get a chance to try the 1125 rf/1075 lf this past weekend due to a twisted axle. Our dynamic roll center is within a 6'' ball left of centerline. this car has a history of bottoming rf. always had stiff rf. May be overdue for a change LOL as we do have a 750-850 springs on hand.
I've ran a full metric frontend in my 04 Loose Gruff for 5 years. The springs that I found to work best is a pair of 750s, but we are on a fairly hard tire. The RF tierod did hit the frame, but now I run a bent one and it's just fine. The control arm itself never bottomed out on the frame. That was in a 2600 LB racecar. It never seemed to matter what was in it for a RF spring as far as travel went...
