RaceMentally
When choosing the chassis you have in your coral why did you pick them? I think I may be right saying you do not use lower a arm offset bushings, the brackets on your chassis are not degree to length matvhed for scaling purposes/indexing, you run a spring pull bar or only 2 bushings in it while still running a 90-10 with a bisquit set up. In which you tend to forget bushings do not store as much energy as a spring pull bar. Shall I go on? After all your car is for sale.
