Make sure your fuel filter is not paper. The e-85 will eat it up.
How about timing and heat range on plugs from gas? Does that change?
typically timing on e85 is on the high side (35-36)
HOWEVER---stay conservative if dyno testing is not available
several factors go into a total timing number
altitude
fuel curve (based on carb and fuel pressure)
exhaust system
actual "ethanol" content
and always ---is your balancer marked correctly
34 is safe in most cases
we run the same plugs for gas --E85 and alky
great tip from racinsparky on the filter
Brad
www.race-1.com
