The 1060 has an anti drain back valve and the 1061 does not.
use short filter oil wont run uphill
I run AMSoil in my car, change it once halfway through the season...see less wear than when I ran Brad Penn. Has a really...really high burnoff temp, and helps free up some power. Yes...its more expensive...but what if a couple more bucks a quart in oil...when your running a $6k+ race engine...CHEAP insurance.
If your interested in some, shoot me a message! Ill cut ya a decent price.
if your oil has an API circle on bottle do not use in flat tappet engine unless you add a zddp additive. It does not have enough zinc. Flat tappet engines need a minimum of 1600 ppm of zinc.Race flat tappet engines need 2000 ppm.
I just posted this on another oil question thread.
Here is a great site and forum for oil.
http://www.bobistheoilguy.com/
The Oil Analysis Reports in the forum are really good info.
Redline has a great site. I have a problem buying an oil when the company doesn't openly show the levels of whats in it. This is an impressive oil. Zinc and Phos well over 2000, and a Flash point of over 500 degrees.
http://www.redlineoil.com/product.aspx?pid=14&pcid=1
Are you trying to give people good honest feedback?? Or trying to sell your product?? How do you know that Redline gives you less wear than Penn?? Are you a machinist?? And how do you know it frees up HP?? Have you compared back to back dyno pulls?? You can look back on my post as I'm sure you will & see that I have never said Penn is better than xxx. Penn,Gibbs,Purple,Amsoil,Redline,Lucas,Shaffers,Mo bil1 all offer pretty much the same protection when it comes to "RACING OIL". Some people prefer Ford\Chevy, some prefer Penn\Gibbs & all can & will win. But when you have Chad Mullins running Penn only in his 9200rpm $18K Modified engines how can you go wrong?? Just saying....:mad:
has anybdoy tried to run motorcycle oil? my engine builder suggest that to me.
51060 has a anti-drain back valve
51061 does not
A anti-drain back valve is only needed when running a oil cooler mounted higher then filter.....
However !! the non "R" filters only flow a max 9-11GPM (depending on oil viscosity)
As where the 51060R,51061R,51069R will flow 28GPM & are specifically made for racing duty above 6,000 RPM........
