Dirtrunner35
Yes your driving style could have a lot to do with it. Ok, I wouldn't have a 78 shock on rf, it will make a car tighter on entry, I would use a 75. To me, the rear shocks seem a little stiff, but they might work for you. The wheel base, longer on the left side, will make a tight car both on entry and exit. Make it even or longer on the right side. Less cross, more stagger, more air in RR tire. Do you run bleeders?
My Rf tire will roll over also if I drive it in off the gas, turn then get on the gas but if I go in on the gas and slide it in, the RF is ok.
