I think your understanding is correct. only thing i will say in addition is that the spring behind on a heavy/rough track is about impossible to drive. JMO
We learn by trying so give it a try but i wouldnt spend too much time on it.
This weekend I went with moving the LR shock behind moved the pull bar over (left) 1 inch(it was right of center 1 inch).
I race on a VERY small bull ring(VENTURA RACEWAY) with very little banking on the bottom. (which is the prefered line) I couldn't keep it down on the bottom and still had the same bite off the corner.
Next I'm going to go from 30lbs of bite to 70lbs. Any Ideas??????
Did you move the lr shock behind or the rr shock behind? Have you tried to reduce the rake in the jbar?
I moved the RR shock to the rear and moved the pull bar to the left 1 inch for this weekends race and the car was tighter in and had little drive off. I still had 30 lbs of bite in it.......I am going to put 70 lbs of bite in it for the next race.
****Question is will the change give it more drive off or just make it even tighter?
On my car when i up the bite it is looser in and more drive off.
Both changes you made would make the car tighter, one on entry, other one on the gas. Increasing lr bite should loosen entry some and tighten the car off. How close are you to bottom out rf shock? Are you trying to loosen the car up some? IMO, look at the jbar rake, I recommended 5in of rake and the dw8 guy recommended 4.5in of rake. Good luck.
depends on if you have a split valve shock or not. if its a straight 5-5 or 4-4, it wont matter as much because the axle sees the same resistance in and out. on a split valve its going to make a difference.
i ran a 4-3 on my rr, spring on top with lr spring in front, shock behind. car was a little tight in. i took the rr and moved it to the front, freed me up just enough and felt much more comfortable to me so i left it there.
theory is as the axle wraps forward on decel, it momentarily sees an increase in weight on that wheel as the shock is on the compression side, thus planting the rr a little more than the left (if shock is behind). does the reverse if you put it in front. its not a huge swing one way or the other, just a fine tuning tool.
On the RR....225 spring on top, 95 pro shock behind axle, 1/4 inch lead in RR. 7 inches of Rake in the J bar.
Two things I want to change is the bite and the rake. But I will make the bite change first from 30lbs to 70 lbs on the LR....if that dont give me the forward bite I want I will make the J bar change.
I agree with the last statement here..."Its not a huge swing" If you’re so tight getting in that you can’t keep the car on the bottom and your lacking forward drive...the shock placement isn’t your answer. JMO of course
J-bar won’t help drive off necessarily. It will help your entry which will let you keep momentum and ultimately make you faster... that is a lot of rake to me and is probably why the tight entry.
Too both loosen the car getting in and tighten coming off, increase your LR spring rate and decrees your RR spring rate. This will be a much more effective adjustment than shock placement but not as drastic as moving your RR spring to the back of the housing like I suggested earlier. I guess it depends on how close you are. .1 second off…move the shock .5 second off…change springs 1 second off…move the spring.
I agree with you adding more LR bite. Pretty sure your headed the right direction with that.
I also agree on the right rear spring being to heavy.I ran 225lr and 175 rr. Changed to 250lr. kept 175rr and the car got way better bite off. Good Luck
LOL, great question Powerslide...I just assumed it was pushing.
In that case, you are loose getting in or no side bite...work on that J-bar.
I would get the large split out of the jbar drop it on the frame then go from there 5in split instead of 7.
you never confirmed 9in or q/c so i am basing this off 9in. if its q/c you need to move the pinion end to reduce split.
How much trail you run?
Sounds like if he fixes entry/middle he will find alot more speed coming off.
tried a wheel spacer on lr or rf?
Hey powerslide, for my own knowledge what does using a spacer on the lr or rf do? Thanks
