Dirtrunner35
A lighter right front spring will put less weight on that tire. A lighter spring does not cause more weight to be there. Ok here is where you disagree. A lighter spring does NOT cause more g-force in a turn, so it can't put more weight on it.. You said this yourself, ( Adding a stiffer RF will also keep more load on the LR which can easily cause a push while on the throttle.) So putting a lighter spring in the RF, you make the left front work more. More roll does not mean more weight. You only have so much weight transfer in a car, when changing springs you change where it goes.The distribution of weight changes.
