really?
this is our old car it won 5 in arow before it was parked the springs in it are fine but you only need 40lbs of split in the rear and dont worry about the front and if you use a jack with a socket like they used in the old days under rearend the rr will come off the ground about a half inch before the left rear ,the car needs to be where brian told you and the problem is all that left rear is absolutely your problem nothing will turn with your numbers they are right about swing arm numbers!
