what is your wheel base on each side? if you lead the rr vs trail, that will help sidebite through the whole corner.
I'm even up. No trail or lead. Running the Left Bottom bar one hole up from bottom, so it shouldn't be getting too much rear steer neither.
Have you tried taking a little angle out of your j bar? Sometimes too much will angle will cause it fight itself getting over...good luck!
Thats what I'm trying this week if the weather holds out. I also found that the rearend was out of square aswell. So it is back to where it should be now. I've also dropped the Jbar to 7.5" on the frame, removed 1% from the rear and dropped the RR top link to the 3rd hole down. We will see.
