Keyser made some overpriced gimmick that doesn't actually work as intended!? Say it aint so........"DATA ENGINEERING TECHNOLOGY ACQUISITION STRING BOX WILL INCREASE TRACTION AND WHEEL LOADS USING ENGINEERING AND DATA TECHNOLOGY"
It works. It just has frequency limitations as Ghopper mentioned. I haven't looked at price for those specially, but that technology is much cheaper than an lvdt.
In general, data measurements practice is very crude and not well done in our sport, where it is done at all.
Those expensive smashers that auto run are great to compare with a guy that has the exact same equipment as you, but are terrible for actually knowing what you have.
I love when a guy just has to spend that 7k and then he says all my numbers are totally different with this machine or what's even better is the guys that aren't even smart enough to catch it they just assume it's the same and "right" because it was expensive and the big guys use them.
Good discussion in this thread.
Thx for the info.
It can be argued that is the intent of cars with the oil cooler scoop facing the rear spoiler. I did not test to see if that works, or just creates low flow across the heat exchanger.
I put my cooler under the deck with a fan for the last ~13 races I have done since 2018 (smh). This years car is standard Mars supplied Keyser cooling package. I will test relative to my Fluidyne system.
Rear facing louvers is something that I have thought about also. I'm not sure how to test the efficiency of the sizing or the number of louvers in an area. I would think they would need to be placed in an area with high velocity non-turbulent flow to get the best results.
