Maybe he however was not that far off base after all given the fact that Overton won and EPJ landed in 4th at tonights event and old Larsy came in dead last ?
I will have to ask him ... He will probably say "Try as they might they still can't stop a Longhorn from winning " ...
Overton doesn't claim ignorance or a broken part in his description of what happened. Like I said, there is more lying in racing than fishing.
If you read the DoD article, Francis basically says he isn't gonna say much about what was wrong cause they got this stupid rule that's a lot more than how far the lr falls down. He doesn't wanna give away any secrets describing the test failure.
So, he had a shorter rr shock or one with too much rebound, something like that. You get the rr down, the car doesn't lift as far to get the lr off the ground.
I'd have to rebuild the rear clip on our cars to run with those guys.
Sounds like tire testing 101. Bust a guy for flunking out on a tire test, but lets not tell what was in the tire that made it fail.
Those guys with tires said all they was told was that their spectrum was wrong.
Droop rule is just a measurement. I doubt they tell you how to fix it, just how bad you were. You still frame a pic of overton car and measure everything, his lr is very close to same drop out as our car, but we'd fail by 4".
Bobby Pierce, Zack Dohm, and Jason Feger are 3 that were never told what made their tires fail. None of the guys from "tire gate" were ever told what made their tires fail. Unless something has changed, thats nearly 10 guys that didnt know.
Failing to meet benchmark doesn't tell anyone anything.
Tire rule, lol………
It's funny, you have all this engineered rear suspension on these cars, 4 -bars, and shocks of different manufactures with the different options for valving. It's now all control by a pc of chain and this droop rule. Do I understand it, basically yes, do I care ? Not one bit because my days of laying under a car are over.
The funniest part about this rule is the guys in charge act like they are doing it to keep costs down. All it’s gonna do is make people spend money to engineer stuff to try and beat the measurement. Two of the easiest things to do to make your car faster are add drop and raise your spoiler up, and they both don’t cost a dime
If they wanted to cut costs, they'd take downforce out of the cars. They wouldn't be obsoleting parts every winter. They just want spec cars. They don't give a crap about cost.
well said mastersbiult , very simple and correct assumption .......
