TheJet-09
I'll try to describe a LR set-up I saw on a car at Brownstown around 2000 or so (I don't remember who it was, but if Matt49 was around back then he might). The LR birdcage was two independent pieces, with the outer half having two links mounted to it (normal configuration, running forward) and the inner half having the spring/shock mounted to it, in front. From that inner half was a link mounted to the bottom that ran forward/angled upward to the chassis. When the LR lifts in the corner (and under acceleration), the mounting point (chassis end) of that link also raises, which in turn rotates the bottom of that half of the birdcage up, thereby keeping a load on the spring (or at least diminishing the loss of the spring load when compared to that of the old style birdcage with the spring in front). If it sounds like that would work, I could try drawing a picture to make it clearer. Thoughts?
