That makes sense and it definitely helps me understand it better. Thanks for all the information.
What left rear shock do you prefer with a soft rf spring ?
I'm sorry I thought you said lr spring...8-2 for lr shock
Trailing my car works for me & even with a 1 1/4 trail my car still drives streight but it is freed up and that what took the heat out of the rr and now thinkin bout goin to 2 inches of trail.. but it is working for me but not sure why the next guy might not like it that way but every driver is not the same i guess but it is workin fo me...
i just plumb bob the rearend but now im just to the point that i just keep pulling the rr back without measuring it but seems to keep getting better..but if ya keep pulling the rr back till it gets loose on exit then put lr bite in the car works out great..
Check your PM
dirt2
ya ever watch a 4 bar car the one with lots off rearsteer is fast & the streetstocks here are running rr back an inch and they are fast and i found out looser is faster i started running to the front when i did it and times are alot better so if its a crutch it dnt matter to me its movin me to the front.. I tried it i liked it and it gets me to where i can exit almost perfect becouse it turns in with no effort....
