fastford
the first bearing cages that cam out did not have as good of bearings as is available now , the newer bearings are sealed better and require less maintaince , we have some older cages were running on a car now with newer bearings that work just fine , krooser , i know your a budget racer like me so you might find some older one,s at a bargain and upgrade the bearings , i have a pt number some where for a very good bearing that could be purchased threw motion industries , if i can find it , i will send you a pm.....one other thing i have herd of , but dont know for sure , but you may can have your teflon cages bored out to use a bearing , if the cage tube is thick enough...
