rob burgoon
I don't think 45 is the limit I'm running into. Once you use up your travel, *clang* the axle smacks into the limiter (undertube in my case). Once this happens, changing the static angle on the LR bar to be steeper won't change much. When the clang happens, the angle on the bar could be 30, 35, 45, but none of those should be very different other than how fast the rear of the car came up.
Adding more droop travel should allow the clang to occur later and for more dynamic LR bite from the "vertical force".
