Ok guys I was talking with a fellow racer yesterday about panhard bars and adjustment he said he searched the forum and found lots of conflicting info on adjustment and was left with even more confusion. So maybe someone with more knowledge then I do can help make all of us more informed. Let's start by looking at what each adjustment does individually. What does it do (tighten or loosen and where) if you only raise the panhard bar on the frame? What if you lower it? What about if you only change it on pinion up or down? Lastly both together up or down. Thanks guys
