How to Adjust Droop to control Rear Steer
After reading the stagger threads, i was curious to how someone could come up with a good way to control the rear steer in a car according to the cornering of a track. The stagger thread used wheel spin ratios and corner radius to dictate correct stagger for maximum tire patch use. How does the rear steer come into play. and we often adjust the droop to let the car jack up or hold it down, and track the bar angles at dynamic state and the rear steer movement. but really dont have any idea in a geometry way to explain what works better. For example what works better in certain situiations. More rear steer when?? Any comments on this.
What should the travel be from bottom of top bar to top of axel
What should the total travel be from bottom of top bar to top of axel so that I could figure out the length of chai needed.
