We were told by our last car owner to put 60 lbs more load on the rr. What will that look like on scales?
Depends on the motion ratio of the RR suspension. Could be about anything scale number wise depending on car and what you have on there.
Easiest way to do what he says is (assuming he was talking ride and dynamic load - just a 60# increase everywhere) is to just divide the spring to the measurement and compress the spring that much more at ride height.
Example 225# RR spring. 60# / 225 spring = .26"
Spring is compressed to 10.625" at ride height so add rounds until that measurement becomes .26 less at 10.365"
PS 60# isn't much of a change, IMO
I agree with billet i have had drivers tell me they can feel 25-30# in the rr but just because they could tell their was a change doesn't necessarily mean their was any significant change on the stopwatch. When we want to want to get a definitive change from a car we typically change 100-150# on the rr
May I ask what he is trying to accomplish? I see ~25#/turn on @ ride height on MY 225 spring, no rubbers and Integra Shock threads..FWIW
In my prior days before smashers, 110-150 lbs of lr bite was common. Whats a ballpark for todays setups?
What car/engine....and (springs just curious). I can only provide #'s for Rocket Blue front car.
Use builders baseline. They can’t make a setup baseline for each car and set of rules etc. After that once your care is decent you can take advantage of all your rules and fudge ride heights etc once you roll it back on scales after you smash springs and make changes you can end up way different then baseline statically but your dynamic can be virtually the same as your baseline but you will be taking advantage of a lot of other things.
I'm going to play devil's advocate here. Which dynamic? We typically pick a point or two. There are a whole bunch of them in between. Some will be the same, some won't.
Dynamically...Toss in a bump spring, spring rubber/s or stop to muddy the water....and amount of rebound in shock where it has you hovering dynamically and spring pushing back depending on quantity and quality of them, available surface traction......clear as mud! Take good notes and data!---------------- To original post... simply.... more RR load, less LR bite from where you were on scales, but more than that going on.
You guys not scaling your car and checking your static weight on your rear wheels let me know how that 100 rr heavy works in the slick..
100rr heavy in the slick will most likely end up in the inner wall or infield frequently.
Static wedge numbers mean very little.
Dynamic numbers are what really matters.
Scale numbers tell you left and rear percentage for setup purposes.
Reading dynamic numbers is impossible on scales, but a spring smasher can give insight.
Then there is aero numbers to add even more confusion.
I would argue that both Scale and Smasher (which are by no means "dynamic") numbers are important. There are maybe 2 or 3 people in our entire sport capable of actually closely calculating dynamic wedge, taking into consideration all of the non elastic movement of weight. Even then, what good are those exact numbers really? For our purposes, BOTH static and "smasher dynamic" wedge are important because all we are looking at is the relative difference. If I scale the car out with a 50lbs of "bite" then adjust the C/O nuts to give me 150lbs of bite, I will undeniably have more wedge than I did before (on track). Likewise, if I change from a 200/400 stack with a bumpstop to a 300 lb spring with no stop (RF), I will also also have more wedge. Do these smash numbers or scale numbers closely approximate any numbers that the tires are seeing on the track? No. But the relative difference between the changes are relevant and useful for tuning.
Your absolutley correct but with all the manipulation of ride heights and use of staged spring combinations. It pretty much makes static scale numbers completely useless for anything other than setting front end geometry, percentages and rear differential lateral location. You can crank all the static lr you want into my car but it will have virtually no effect anywhere but possibly on a slow restart. Our if the driver has to turn right abruptly at the end of the straight away to avoid somthing but we don't really setup for those sorts of things
You can do things many diff ways.i prefer just scaling and no trick springs ..i have found that this weeks newest speed trick never works...it depends on where you race the big rr spring soft lr or stacked works great some places it sucks..some tracks like a stiffer lr than rr spring. You just got to have a feel for what the car needs..im not saying stacked bump stop on rear doesnt work or proggressive this is where the smashing comes in... But they aint no way in hell im leavin the shop without knowing what my rear wheel weights are...i have won races 100 heavy rr on a single leaf car and 150 heavy on lr on a 4bar flat and rr heavy some tracks diff conditions..
One more thing .i think all this stuff has killed super latemodel racing there should be a spring rule no proggresive,stacked,or bumps keep it simple the little guy that has to work 40 hours a week that has no time to test and manipulate setups with bumps and progressive springs.thats why the small time guys have left. Shocks too !
I help several race teams, all the guys that I helped last year ran a class lower than late model. This year, one of my older race acquaintances returned to dirt racing, he had been running asphalt tracks for 5+ years. He bought a 2014 rocket chassis. It is NOT a XR1, but it was supposed to be as up to date as a chassis of this age could be, and the people who were helping the previous owner are very respected in a 3 state region. Once I got up close and personal with the chassis, I was caught off guard by how different the body was. Once we began to discuss the setups that he was given for the chassis, I was really caught off guard. In other words, the stuff that won races 8-10 years ago is absolutely out to lunch now. The modern stuff that is competitive is absolutely just one huge spoiler, and the shocks and spring just keep that huge spoiler constantly up and in the wind.
I agree totally about the aero on these things. There was a reason they outlawed wedge cars years ago and it seems like it’s that’s where they are headed back to. It definitely hasn’t made the racing any better, especially on bigger tracks. Would love to see someone start taking a 2” hole saw to the noses or a minimum height to keep the noses in the air. They are so low now that if you bottom the RF it folds the nose over and your done
