Bdcase19
Someone who understands. AndMe being young has nothing to do with it. I've been around it since I was real young and I know what IKnow from experience, from countless hours on the scales. Most people stick with what hasWorked for them, which is alright but yourNot gonna get faster if your setup is always the same.You can adjust all four corners and leave the rifled height the same while raising or lowering bite and front split. You can also raise the rear (both sides) not equally a take split out or put split in without moving bite. Same goes for the front or for the left side or for the right side. Remember NUMBERS don't lie. And like I said with the exception on cross the percentages are static weight numbers. They do not change unless you move or add/ subtract weight.
