Looking for a rayburn chassis and some parts who's got something laying around
I have a combo chassis and probably enough spare parts for 2 cars
Dinka2 2 you called me this morning -- this is what i have
rayburn revolutiion chassis [2011/12]
chassis never been bent one small modification in rear for clearance
front:
18 sweet rack with steering arms
10* spindles brought car alive
upper and lower control arms
strut arms
wilwood hubs, rotors and calipers [on all wheels] and master cylinders
hurst right front lockout
will need --to finish steering shaft
throtle peddle
spares steering arms
7* spindles as spares [stock]
r&l strut arm
c**ckpit:
Quickcar 4-gauge panel
quickcar switches
will need seat and belts [wrap-around type belts were used on shoulder belts and bolt in on lap belts]
rear:
Standard quick change used [4:86]
car is on 4-bar setup now
swing-arm componets will be included
j-bar and lift bar with 6th coil
fuel cell:
I had a heavier fuel cell can made based on a standard rayburn can it has a roll-over valve, flapper valve, and sprint car brass pickup in the
rayburn tank i do have the original can
shocks:
I have a set of 6 bilstein available that were valved at the reyburn shop
they have very little use
body:
Blue with white decking i think i have several sheets of blue which will be included
i am sure i have left something out but those items will be included in sale i would not hesitate to put my driver our son in it.
I have a 2017 Rayburn by rsr. Frame,good raceable body 486 frankland ,all front and rear suspension. Has the raised crossmember from rsr needs rack brake calipers and fuel cell to make complete car has about 30 nights on it. Two one seven. Four nine one 1194 Negotiable on price
Also has the 10 degree spindles and a bunch of spares to go with it. Located in central illinois
