Im looking at switching my motor over to gas would you guys recommend a 4 or 6 blade fan to keep it cool thanks for the opinions
Four blade 19 in
Add to above post.....GM 36 deg pitch. Normally its a little overkill, but I'd rather be a little cool than hot, esp. with a new setup.
I run gas in a mod with a 18" 2 blade and run right on my stat all the time, 406 or crate motor. I do have a shroud.
If a two blade works on gas i should not have trouble on alcky.
Currentley running about 180 to 185 ?? No shroud. FOUR BLADE ????
