Price reduced - Stock Car
Price Reduced … Stock Car Roller
Car is a Camaro / Nova front clip tubing the rest of the way back - 3 link rear suspension - all wheels 5x5 pattern - Brand new 26 Gallon fuel cell and new fuel line - one season old belts - new tubular upper control arms - car is set up with a mid plate - has gauges and switches installed also has brake bias gauges - adjustable wilwood brake pedal assembly with clutch pedal - removable steering wheel and Howe steering quickner - Howe floater 9” ford rear-end currently with .514 gear 31 splined axels - also has fire suppression system
Body was brand new at the beginning of the season but shows some wear … but is raceable - newer style Camaro nose and tail from AR Bodies - has a lightweight plastic late model roof from Allstar full firewall (not stock) that goes all the way across
shoenfeld chassis headers - 3 speed Saginaw transmission -with quarter master 6” clutch pressure plate and flywheel with the hydraulic throw out unit - double pass afco radiator
Car will come with lots of spares
This car was the 2006 Eldora stock car champion with Shaun Phillipi driving and was runner up several times in the years to follow - car was also winning races up till 2012 with Shawn behind the wheel - all set up sheets and paperwork will go with the car
Roller with a set of spares $3000
Roller with trailer option $5200
open trailer LED lights all new bearings this year with 5000 lbs winch and new battery storage box on the front tire rack that will hold 6 tires and the trailer spare
willing to deliver within reason as long as you are buying it
