* 07 TCA Metric roller UMP *
2007 TCA metric chassis,81 Performance Bodies Steel Camaro body fiberglass roof\hood,Fabricated steel floor also have the pieaces to deck in like a modified,4 weight jacks,6 Afco springs,Bilstien & QA1 shocks,U.S. 5x5 rotors,Tubuler uppers with corrected mounts,all NEW steering componets in 2010,2:1 Colemen quick steer,New steering box,Afco aluminum pump,aluminum Muncie 2 speed,Triple disc with Hydralic throw out,FastShaft chromoly 2" driveshaft,Quick Performance Metric 9" 31 spline with a 6.00 & 6.83 gears both LW gear & lw full spool,chromoly ACE drive hubs with LW .810 rotors,16gal RCI cell,-8 fuel line with take apart filter,PRC dbl pass rad,Longacre oil,water,volt,5" recall tach,brake bias,ign swithes,alum 2 lever shifter on fab steel drive shaft tunnel,alum kirkey intermediate seat,RCI 5-point,Wilwood duel pedels\master cyl\clutch,4 NEW wilwood steel calapers,Optima red top,Dynatech 1.75"over rail headers,Toe gauge,caster\camber gauge,bump steer gauge,stagger tape,tire press gauge,air rivet gun,wheel spacers,cherry picker,engine stand,several 8" tire\wheels,New in 2010 Willy's gauge legal 4412 2bbl,500lbs lead,set up books & what ever else I can find you will get.Top 5 everynight @ Macon,Lincoln,Farmer City,Fayette Co !
Brian
http://www.racingjunk.com/category/7...ller-UMP-.html
