We have a max of 410 lift at the valve which is approx. 250 lobe lift this is a stock rod 7000 rpm needs to be a hyd flat tappet stock head & 350 carb what are your thoughts on a good race camshaft
Is it .410 after lash?
its a hyd with a max of 250 lobe lift which = approx. 410 lift
Duhh that was a terrible question should have read ur post a little better check out the RACe engineering site they have one perfect for u I believe its the 242
great thanks
brian, why does the roller cam valves use a .400 tip and the non-roller use a .550 tip? thanks.
olin
