billetbirdcage
Actually, the problem isn't the bars hitting the frame that I recall but there were some older cars when using newer type set ups that the birdcage could get into the RR frame rail. The real problem is the RR tire will rub the outside of the RR frame rail and pop the tire, if you get some j-bar rake into. You will see black marks on the frame rail, the only way to fix it is to move the framerail over at least 2".
Honestly, I would pass even if it was really cheap. What are you getting there and how much of it isn't going to take a fair amount of money to get it usable? You're guessing the rack and the rear end aren't going to need a ton of work, then what about the brakes? They look to have been sitting quite a while, all of that could need gone thru and need new seals and pistons in the calipers. God now's if the master cylinders are even any good after sitting.
Then the fuel cell: That cell was new in around 95 or so and many had real issues with them, Bill Frye had to turn his side ways in the car to get the car back to where it was before the cell. you can look at old pictures around 95 to 97 and see his and Verdin's cars where both that way.
So how much is really left to use? I honestly wouldn't pay much at all for it, unless you could inspect a bunch of the parts to see if they are even usable without spending cash on them. Too many other cars out there just as cheap, it's a buyer's market.
Just my opinion
