Rod Angle left to right
Does the 4 link rod angle have a noticeable effect? At ride height my RR top bar is close to parallel but as the rear shifts under droop the RR top angles right more than the LR top bar. Is there any benefit to getting the RR bar parallel with the chassis at full droop? Birdcage and shock angles are in the correct position. I've seen a couple cars with the RR top bar mounted outside the brackets to straighten this angle (5/8" bolts) and considering if it's worth the effort?
Sorry about the duplicate post. I don't know how I did it and I've tried to delete, but just ran out of talent and time.
Thank you. I have search this page and others for this same thing for days. Guess you need the search words just right to get results. Thanks again
