GM 604 Crate sprint Program
GM 604 Crate Sprint Engine Program
Pace Performance/ Race 1/ Blackshear Racing Engines
Base GM 604 Engine Package
w/ rear cam accessory drive installed, including balance hub w/drive yoke. $6,250.00
Entry level Complete 604 engine package includes
Pace Performance/ GM 604 Sprint Engine:
~With rear cam accessory drive installed, balance hub including drive yoke,
~HD Alum water pump, Alum V groove pulley kit w/belts,
~Fuel pump & Thermostat block off plates, Water fittings
~ Holley 750 cfm Alcohol carb ARP carb stud kit, Bypass regulator, Carb fittings w/fuel log
~ Carb spacer plate w/ linkage kit
~Washable Air filter kit,
~Taylor/Vertex Mag w/wires, NGK spark plugs
~Blackshear/ETI 7000 rpm rev limiter
~Schoenfeld spec headers, 8qts Break-in oil w/Wix racing filter.
All parts and engine are race prepped including Dyno break-in and tuning.
Complete Total Package Cost $ 10,250.00
Package does NOT include: fuel pump, power steering pump,fuel lines, water lines or mufflers.
Elite package upgrade: Stealth Custom Carburetor, Aeromotive bypass regulator, KRC water pump, KRC serpentine pulley kit w/tensioner, R2C air filter kit. Add $1850.00
Contact:
John McDevitt/Pace Performance 800-748-3791
Don Blackshear/Blackshear Racing 724-977-7424
Brad Hibbard/Race 1 330-540-7223
