scaling problem - Cant get the bite down
Having troubles getting the bite down. We normally run 120-130# bite. Car now has 180# and cant seem to get the bite to adjust. Scales have been leveled. All corners have been checked for binding. Let out all gas in shocks. Removed all fuel and started placing it on top of decking slowly trying to change it. Noticed something odd that when we place 25# on RR it removes bite about 10#. than i added 50# more to the RR and it does nothing. We unhooked 5th coil, dropped RF over 1/2 inch from normal ride height and it does take about 30# bite out of it. We had LR shock as low as it will go which is 5/8inch lower than its always been, which this does help but the LR ride height seems really low. We have always have standard ride heights for LF,RF,RR and adjust LR, but raced it one time and the car was terrible on getting on bars and looked really flat. We have checked every hiem numerous times. running out of ideas? Noticed it is having hard time rolling on RF, on cautions when driver rocks the car and general you want it to climb nicely on the bars it does very little, only when there is enuff traction in the track will it hike up correctly. looking for ideas is all. Tried so many things we normally dont even do. Removed axles also
