Schoenfield now makes a anti reversion muffler also.Just came out 49.95 each 3 in inlet 3.5 outlet.
Schoenfelds said if you are running the mufflers ditch the extensions
schoenfeld is correct if you are building a dyno queen. otherwise, you'll want some extension with their mufflers.
So do these mufflers make the exhaust sound less loud at all?
It made our engine sound totally different I would say it is not as loud as the dirt pros we had on also a lot less wgt than the dirt pros.
Just wondering if these have been tested with stock cast manifolds? Been reading about them and cant find anything for cast manifolds. Also would they work the same with 2 1/2 exhaust pipe ?
I also have a 11.5 to 1 motor would these help or not much gained ?
John
