What to expect from this motor?
I just picked up a motor with the following specs wonder what to expect for performance?Fresh bottom end 5.2 rods .060 overOval head factory valves .450 hydraulic roller camHead shaved .140 ARP bolts in bottom end Previous owner had 5 races on this setup said he ran 8200 rpms? Rpm seems hard to believe? Would this engine benefit from a larger cam lift? It appears the cam is a custom grind the numbers on the cam are the following:PC-HRT-9509-9508-11.115 2020R. Thanks you guys are great
