wat is the best spring angle to run both rear springs on a 4 bar 4 bar spring behind lr and spring ahead rr
Im not at home to measure the angles on my cars right now. But the car with more angle in at the top on the RR rolls over easier,lifts the LF tire higher and does not feel as stable as the other 2 with less spring angle. If on the RR , the spring does not provide as much resitance with more angle. But it does work well on tracks with tight turns. Hope this helps.
