Garage Clean Out
9" ring & pinion 5.43-$50
Wide 5 allum hub & rotor $ 50
wide 5 caster camber gauge with box-$50
5-wide 5 drive plates- $25 all
flywheel for a reverse mountbellhousing, steel ring rest is allum, has belt drive gear on it-$100
Quick change top shock mount-$5
2-carb spacers 1-4brl wood, other 4 brl to 2brl-$10 all
MSD 7000 rpm module kit(5 chips)-$5
Stud girdle no pollylocks-$10
Complete set 3/8 1.5 long slot Manley stock type rocker arms w/pollylocks-$10
Pull slave cylinder with line-$10
Several tube upper a-frames, 6" center bolt on 5 that are 7 3/4 2 that are 8 1/4 and 1 that's 10 1/4 all for bolt in ball joints $20 ea
Priced this below 1/2 price, want it gone! Call chuck 573-223-7059 or call or text 573-429-8703 can send pics on phone
