Over $13,000 invested in this Lightning mod, your price only $6500
Lightning Chassis dirt mod for sale. . You can buy it as complete roller less engine and transmission assembly for $6500. Will separate more parts if you want to purchase for less money and don't need all that is there. Over $13,000 invested in it the last 18 months with original purchase and all the new upgraded parts installed. After purchase was torn down to bare chassis, chassis sandblasted and painted and reassembled with all new wiring, gauges, radiator, seat, belts etc. Also installed all new Winters light weight and low drag ProMod rear quick change. Also added all new aluminum brake calipers on all 4 corners at that time. Ran it 15 races in 2017. 5th in points at Volusia Speedway in 2017 in that configuration. Last winter upgraded complete front end with Lightning tubular lower arms, new upper arms and all new steering, steering column, suspension, spindles etc. for wider front stance for better up to date handling. Ran 8 races with it this year. Only selling now because a sponsor has helped us purchase a new 2018 Lightning chassis and need the cash to buy parts needed to complete the new assembly. If this car not sold in next three weeks it will come apart and we will use the quick change rear and lots of other parts to finish our new car. You won't find a better deal than this as you are buying a freshened and upgraded race car you can race for a long time before having any maintenance expense, not buying someone's worn out race car that is going to give you trouble finishing feature races in. http://www.garygrossracing.com Will deliver up to 1000 miles from Daytona Beach for the price of gas.
This still available and where are you located? And is it on 4 bar?
[QUOTE=daytonagary;2211899]Frame sandblasted and paintedfollowing parts bought all new, rear start of 2017 season, front end suspension/steering start of 2018 seasonWinters Promod rear end lightened and low friction5x5 hubs, gun drilled axles, shortened axles for light weight2 inch fast shaft drive shaftWinters aluminum brake calipers all 4 cornersAfco double pass radiatorBrake Bias gaugesAll dash gauges and switches with new wiringChrome Aero wheelsSeat and beltsWidened front end suspension system from Lightning with all new partsupper a arms,
