Parts and old HOWE dirt chassis
Early 90s Howe Eckrich Precision Performance car driver by Ray Guss Jr. fresh front stub, pipe, decking and bumpers, have misc front and rear suspension, NO: hubs, shocks, springs or rear end. $1000
SHOCKS
Afco dbl adj canister m2 wheel shocks (RF, LF, RR, LR) (RF, RR, LR all done by Shy)
Canister clamps included.
Pop up traction shock with adj compression
2-5th coil oil shocks (dry slick, mud/fast) by shorty
Shy dyno sheets are still missing and have one of 5th coil sheets, LF and traction are still valved how afco sent.
So 7 shocks $1000 plus shippingand paypal fees
Afco LR traction shock (pop up) 92276 3190CA used once $150
2-Afco rear dbl abj shock used $200ea
2-Afco LF 1376-2 used $100ea
Afco LR (7-3) shock new 1397-3 $100
Afco 10-90 shock used 1171-9 (rayburn, pull rod set up) $50
Push/Pull air shock $50
TOOLS
Pit Boss aluminum racing JACK (NOT WHOLE CAR LIFT) by MPD $2000 new $650
Montgomery Ward 3hp 120v 1100watt generator used $150
ENGINE PLATES
2 TNT / MASTERSBILT Ford
1 PARKER / RAYBURN Ford
1 PIERCE Chevy
1 GRT Ford
all used $50ea
GRT PARTS
2 sets aluminum TWM bird cages used $75pr
LR traction shock mount $50
Aluminum rear brake mounting bracket set $75
LR Radius rod mount extension brackets for using shorter lower bar $25
5th coil upper mount $20
Steel lift bar mounting tabs 2 lower 1 upper $10
2 custom made lift bars used $75ea
PARKER / RAYBURN
Set of new spindles $100pr
3 Front bumpers 2 wedge 1 conventional $25ea
QUICK CHANGE
Winters Magnesium hubs, 1 steer $75, 2 drives with rotors $200pr
Aluminum Gold Trac LWT used $375
Aluminum axle tubes (26 & 29 overall) used $50ea
Axels: Std used (32) $25
Gun Drilled used (32, 3-35, 37, 37.5) $50ea
Troyer Alunimum j-bar pimion mount 13004 new $25
Aluminum j-bar pionion and frame mount set used $75
Aluminum j-bar frame mount $10
Steel j-bar (24) $50
Afco pull rod spring 27105 new $35
Steel drive shafts with joints and yoke (34, 35.5, 2-36, 36.5, 38.5) $65ea
Aluminum drive shafts with joints and yoke (36 & 36.5) $100ea
2 sets Aluminum rear brake mounting bracket $75pr
2 Aluminum bolt onto bird cage lower shock mounts $10ea
2 Aluminum 90-10 mounting bracket sets $10ea
Steel radius rod frame mount plates (misc) $10
2 clamp brackets used $25ea
9" FORD
3.82 gear set used $100
Lefthander 58" housing new $200
2 5x5 hat style brake rotors new $50pr
Strange brake caliper with rotor new $25
EXHAUST
Dynatech Ford Yates Parker / Rayburn headers 4 into 1 RT side header inside frame rail 1 7/8 to 3.5 used $150
Stainless Chevy SB2 Tri-Y headers (NASCAR), used $400
Schoenfeld mufflers 83535 8"L 3.5" dia new $50pr
Borla Stainless mufflers 40004S 13.5"L 3.5 dia new $300pr
Shorty Ford V6 headers for SHO or similiar used $50
BRAKES
Wilwood caliper 120-3191 R/H new $100
4 1.25 rotors used $100set
4 .375 rotors used $100set
2 .375 rotors used $50pr
4 Aluminum 1" brake pad spacers used $40set
3 set of JFZ 005-0993 brake pads NIB $10set
ENGINE PARTS
BUTLER 3 gal square style tank with Oberg on top, 2 in, 1 out, all 16"s $250
Gears Unlimited starter used $100
3-other starter $100ea
Isky Toolroom valve springs 9985 & 9995 used $75set
PSI valve springs w/ titanium retainers CT-1242 used $150set
Carrillo H-beam rods 965B (6.200, .927, 2.100, .902, 641g, 3/8 bolts) new $600
Lentz I-beam rods from Yates (6.200, .927, 2.100, .902, 660g, 7/16 carr) used $350
2 set Ford cast Aluminum valve covers with pop off breather and oilers (clev, mod, yates) used $100set
Ford Aluminum sheet metal valve covers with oilers, yates new $350
Cam Motion SBF roller cam R2531-2533-06 (254/258@.050, .761/.733 w/1.85 rockers, 106/102 lobe sep) used $200
Precision Prod Casidiam .927, 2.750L wrist pins used $150
Remote oil filter housings used $35
Moroso Blue Max Ford spark plug wires for Yates 48793 NIB $100
Erney Elliot Aluminum dbl v-belt water pump pulley EEI-8509-B used $100
SBF W Magnito used $375
Auto meter Pro Comp 2 5" 0-9 memory monster tach for mag used $125
Auto meter Pro Comp 2 5" 0-10 memory monster tach for std ign, dash mount ultra lite used $175
2 sets of steel 2' drop Ford motor mounts used $20set
MSD boxes 6T 6400 & 6HVC 6600 used $100ea
MSD coil 8250 used $75
MSD Soft Touch 8738 used $75
MSD trigger wire NIB 8860 $15
Crane Cams 5/16 guide plates 52650-1 M-6566-A302 (clev, mod) NIB $35
ARP 7/16 rocker arm studs RRS-3H 2.375L NIB $35set
351 Ford 1 piece rear main seal new $25
SBF W 7 qt oil pan, oil pump with pickup used $50
16" K&N plastic lids used $25
14" 4" K&N filter used $10
1" cast aluminum Mr. Gasket 4x2bbl carb adapter plate used $25
1" aluminum 2bbl carb spacer used $10
1" 4 hole 4bbl carb spacer used $25
1/2" open angled 4bbl carb spacer used $20
2 Aluminum fuel logs used $35ea
2 Ford Aluminum valley plates 9.200 deck used $50ea
1 wire alternator set up used $75
Peterson dry sump pump belt 05-1909 (656mm x 20mm) NIB $10
Misc lower v belt crank pulleys with bolt used $10ea
MISC
Upper thread in ball joints Moog K727 (1 new 1 used 1 race) Afco 20034 LF new $25ea
Howe large ball ball joint spuds 22430 3 new 2 used $25ea
Howe small ball ball joint spuds 1 new 3 used $25ea
Weight clamps:
round tube 14-1.50"
used $5ea 6-1.50"
5-1.25"
4-1.00"
2-1.50" sp tube
2-1.50" body mount clamp
5-(57-001) outpace Afco canister clamp/holders $10ea
Aluminum shift rod w/ ends used $10
Steering shaft u-joint new $20
2 used pin on sterring wheel hubs with shaft ends, extra shaft end, u-joint all used $25
Draw-Tite class 4 reciever hitch 63-91 GM & 63-72 Ford used $100
15" 3 spoke steering wheel used $20
17" quick release 3 spoke steering wheel used $60
Aluminum window curtain rod w/ spring loaded end used $15
Grey plastic inbox side tool box used $25
Ford mid late mounts used $15pr
Pieced out a late model so more to list soon! Ask if looking for something not listed.
FOR PICS PLEASE EMAIL OR TEXT 815 291 6002
