Over the winter I put new seals in the calipers and added a bias gauge. And my fronts are holding 100lbs constant and zero rear with no pedal pressure. Bled the system manually and confident of no air. Balance bar even side to side and front to back. Even went as far as remove the pushrod and it's still at 100. Pressure on front is exactly 100 over rear no matter how hard you mash the pedal. Any suggestions?
