IMCA hobby stock tech question on trailing arm bolts
I was disqualified last weekend because one of my trailing arm bolts was loose....when I asked for clarification...IMCA said that unaltered rear suspension was the rule it fell under....and that the bolts were tight from the factory...and if the bolt is loose the suspension has been altered....
I am curious...is this rule enforced like this at every track? and...how do you keep the bolts from coming loose?
Also...do you guys know of any more gray areas they might use to dq someone...I am new to this class and don't really like getting disqualified.....
