camaro clip .....caster rf 7..lf 5.. fastboy setup 11 hoosiers.car wants to turn right when on the gas coming out of turn..should I change caster to rf5 lf 2 .....thanks
is it a frontend problem or a rearsteer problem the fastboys set produces quit a bit of rearsteer as the lr moves forward the car tends to turn right. mite try adjusting stagger or even take a little lr bite out.
i fooled around with this a few years ago, and i found that increasing my RR bite, and leading the LR in helped to correct this issue, i think the LR as it wraps will cause negative rear steer causing the LR to move towards the back of the car. but i didnt spend much time with it because shortly after i started using it the track deemed it illegal.
i thought scooter had said you need rr bite like newguy said and a lot of stagger(4-6in) to make it turn with a full blown fastboys setup.
olin
You will need to trail the right rear 1". Have at least 4" of stagger and a low cross percentage or it will push like a dump truck on the gas.
I remember my cross was somewhere around 45
I have mine around 37 right now.
