1 Attachment(s)
Hub bearing grease
How much is too little or too much to use in the hubs?
I run a northern sport mod and I use the DRP grease, seals, and polished bearings.
I used to use implement grease and I didnt need to grease very often (lol) and i went to this stuff and from what I understood I could get a season out of it.
I use a syringe to apply the grease and go every-other bearing, sometimes every bearing and put as much in as I can. Then go back over the bearing once more. I rather have too much in there then not enough.
Just want to know what any one else is doing.
Pics are after 2 races.
if your using drp grease every other bearing is all you need . Putting to much grease in adds a lot of drag to the bearings . At mid season take bearings back out clean them and repack that is all you need to do .
I wish my photos would upload on here. I did that plus a little extra and it didn't seem like enough after 2 races. I added a little grease and I'll check it again. I would like to say it's enough but I would hate to junk bearings if I held off till mid season to re-grease.
